Major oil leak..........wtf?????????
Discussion in 'The Garage' started by bear, Feb 16, 2005.
  1. bear
    bear Registered Member
    Sep 16, 2002
    31
    Georgia
    Hey y'all........please help!!!!!!
    Have an 83 K5 with a 305...Yesterday I had a major backfire......tons of smoke from the tail pipes.......when I check engine there is oil everywhere. Ran engine and found oil literally spurting out of what appears to be a bolt hole on the front of the block down near the fuel pump. Do I have a cracked block behind this hole, or is there supposed to be some sort of gasket/bolt in that hole?
    Please help me figure this one out!!!
    Thanks,
    BEAR
  2. blublaz
    blublaz 1/2 ton status
    Nov 6, 2004
    145
    Tucson AZ
    You may have thrown a rod. Is there water in with all the leaking oil? Have you tried turning the crank manually? Was there a bunch of noise after the backfire or did it continue to run?
  3. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    That bolt hole goes through to the fuel pump push rod. You put a long bolt through it to hold the push rod up when you change the fuel pump. You need to put a short one with some rtv on it in there to plug it. Don't know what the back fire had to do with it, maybe it was pluged by old rtv and the backfire jared it loose.
  4. bear
    Sep 16, 2002
    31
    Georgia
    thanks for the info......much rather be missing a bolt than have thrown a rod........btw, what is rtv?
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    it sealant, the blue stuff in tubes at the auto store
  6. bear
    Sep 16, 2002
    31
    Georgia
    oh......I've got plenty of that in the garage.....
