major progress report..weehoo!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wrath, Jan 13, 2002.
  1. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Hey all !!! Just wanted to brag and tell everyone I got a buttload done in the last couple days.Wednesday I pulled the 350 out of the 70K5 ,Thursday it got 40 degrees out (I'm in Michigan) so I went nuts with the powerwasher and got the engine compartment,engine and spare 3.73 front axle thats going under it hosed down.Friday nite I pulled off the front clip and all chrome trim(ready for bodywork now).And tonite I added the 3" bodylift bringin it up to 7"..looks much better now..Man,I cant wait to get them Boggers now..thanks everyone for all the help with questions so far..just needed to vent
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Did you have any problem's with the install of the bodylift?
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  4. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    Nope not yet,but mind you all I did was lift it and stuff the blocks under it and slid bolts thru..that was as far as I got,did notice the steering shaft was tweeked so I gotta lengthen that and trouble shoot everything else typical with a body lift..theres no engine or frontclip in it so no probs there..
  5. Sounds like some great progress. Wrathchild - what brand did you go with for the body lift?
    I'm tossing around what to do on my 69 3/4 ton. Probably just going to do ORD's 1" body lift but 2" or 3" would be best for what I want to accomplish.
    Did you have any difficulty breaking the body mount bolts loose? I just got done adding some spring leafs to my rear packs to gain a little height and load capacity, added 2" of leafs and gained 3 1/2" bringing my total real lift to 7 1/2". Now I got to address the front end, though the stance isn't bad at all right now.
    1969 C20 4x4
    4" lift, 35x12.50x16 Super Swamper SSR's
  6. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    Body lift was a Performance Accessories.Yes the bolts were a pain, everyone in bed was tacked down (never seen GM go to that much trouble to keep bolts in)anyone seen there bolts mig welded down..anyways once I ground down the weld,the spacer up thru the mounts were all pretty much seized to the bolts so ended up grinding off the heads and driving them down..worked like a charm!!!Good luck on yours Yukon
