major tranny leak
Discussion in 'The Garage' started by kitasjimmy, May 5, 2007.
  1. kitasjimmy
    kitasjimmy Registered Member
    Apr 28, 2007
    44
    Omaha, NE
    I've got a major trans leak in my 91 Jimmy. I'm thinking it is the front seal. I want to try to fix it myself but have never dropped a trans before. Anyone have any suggestions. Is this something I can do in my driveway. Any help would be appreciated. Thanx all!:confused:
  2. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    i've done them in gravel so yeah you can do it in your driveway. if it's asphalt it'll just be a little warm. lol anyhow you'll have your tranny lines, torque converter bolts(3of em), bellhousing bolts(6 but mine only goes back with 4), driveshaft (front and rear depending on 4wd or not) tranny crossmember bolts, speedometer, and i think that's it? sure it's got the 700 r4 so watch out for the linkage going to the carb. if it's a 350 you'll have the one vaccuum line. but all in all it shouldn't take that long. first time i did one it took me bout 45 minutes to take it out. i had a homemade piece to balance the tranny and transfer case though and it went into the jack hole so it made it alot easier. any more help i can think of i'll post
  3. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    oh yeah get a pan under it and pull your dipstick. it'll leak for a bit so go make a sandwich or somethinglol
  4. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    haha i just did it on my gravel driveway you will also need a portable tranny jack to help support the transmission and t-case assembly when you drop it down if you think its the front seal pissin it out be sure to double check its not your torque converter or anything like that cause thats what happend to mine and now i have to fully rebuild mine TCI style but still its a pain to have to pull it again ONCE uve changed that seal already haha
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    If you are only going for front access. would it be easier to pull the engine up a bit?
