Major water leak. Help!
Discussion in 'The Garage' started by seschev3, Dec 6, 2005.
  1. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    This is not my trail rig, but my rig during the week. It is a 95' suburban and it is draining the radiator ever 2 days. The leak is coming from the back of the block. I would think that it was a freeze plug or the intake. Any experience or ideas would be great before I yank the motor to find out. Thanks.
  2. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    I have seen quite a few leak betweeen the intake and the heads. The water runs down the back of the block.
  3. yagsinairod
    yagsinairod Banned
    Dec 6, 2005
    6
    Maryland
    crawl on top of the motor and take a peak in the back. It should be pretty clear where it is coming from.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Use an inspection mirror (a small mirror on the end of an extendable wand, with a swivel mount) and a flashlight and start looking around the back of the engine. You should be able to see where it's leaking from.
  5. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Uh,...................freeze plug
  6. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    remove the bell housing pan and try to see if the freeze plug is toast or if u cant see it because of the flywheel flush the system with a water hose and look for water dripping from that area
  7. seschev3
    Jan 19, 2005
    308
    clayton, ca
    Thanks for the info guys. I will do the mirror trick this weekend. Hoping it is the intake. If I have to yank the motor, I think I will just replace it. Not a good sign at x-mas time ($$$). At least I don't have to do the work in below zero temps. Cali is good for something.
