Major work needed I think, help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by istallion88k5, Mar 9, 2001.
  1. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    Last week I started getting a real bad vibration sound when I let off the gas on the highway, thought maybe ujoints, but then it started at lower speeds, then at an almost stop you here clicking as the drive shaft spins. Then last night, put it in 4 wheel to see what it would do and got the most god awfull sound when I turned left like the wheel was going to fall off, I know I needed new bearings but jeeze would it make that bad of a sound?
    If it aint a Chevy don't raise it up!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    possibly...you might also check your brakes. I would be worried about the front drive shaft, front axle, or the transfer case and maybe even the front diff. There's a lot of things up there that can make noises!
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i had the same prob...it ened up being a bearing in the front...i smoked the spindle and the inside bearing...if i were you i would pull the front hubs off and check em out...and give em a little fresh greese..
    Chaz
    "Hondas look good under a k5's tires"
  4. istallion88k5
    Jun 20, 2000
    139
    Cincinnati, Oh
    I know the brakes are good just got new rotors and calipers few months ago and all is tight. But I do have grease coming out on my damn rims from behind the auto hubs so I realize they must be shot but the noise just bothers me. Have to take all that crap apart in the cold sucks too.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check your auto hubs. When mine went out they would engage and disengage whenever they felt like it.One would be in and the other would be out. They made all the noises and vibrations you describe too. I replaced mine with manual superwinch hubs and everything's been fine since
  6. windrider
    windrider Registered Member
    Mar 3, 2000
    52
    Wisconsin
    My auto hubs started clicking and banging. The locknut on the wheel bearing came loose. I'm replacing the hubs anyhow.
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    it kinda sound like a wheel seal...if grese is comin out the back of the hub..that is more than likly the prob..
    Chaz
