Makin a trailer--
Discussion in 'The Garage' started by misterfnygy, Oct 25, 2006.
  1. misterfnygy
    misterfnygy 1/2 ton status
    Jan 12, 2006
    199
    Reno
    Hey all I got a question-
    I have a 74 1/2 ton parts truck that has the frame just about ripped apart at the steering box. I plan to use the 465/205 for my K5 and keep the motor for something.
    Want I want to do is turn the bed and rear frame of this beast into a trailer to match my blazer. I have an extra set of lift blocks/springs for it so it will match the truck. Here is the question--
    What is the cheapest way to get an 8 lug axle under the rig. I know that R&P doesn't matter so I could just pick up a 14 bolt. I thought someone might have a better (cheaper) idea. Thanks...
    And by the way- if anyone needs parts I don't want let me know...
  2. Captainfab
    Captainfab 1/2 ton status Premium Member
    Mar 5, 2006
    468
    Coeur d"Alene,Idaho
    Try and find an old Eaton rear, they are usually cheap or free. With the Eaton rear you can drop the 3rd member and pull the axle shafts. Then make covers to replace what you took out, fill back up with 90w and you're good to go. This way there is less weight and less pulling resistance. I've done this a couple of times on trailers.
    Another option would be a 14bsf or d60sf, you might be able to pick up one for cheap.
  3. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I would get the same rear axle setup as your rig so it would be like having a bunch of spare parts on hand. for easy trail swap outs if something breaks. Just a thought.
    Remington
  4. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    x2.
    I plan on doing the same thing so I don't have to worry about keeping as much cargo space in the K5. I did one like this for my Toy ('95 SAS about 10" lift over stock with 35's). It sat high enough to run off the bumper, and I had a full spare rear end. Nice thing on that one though, I could use the 3rd member as a spare for front or rear.
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    another option..
    You could use ANY FF 3/4 or 1 ton axle you can get cheap or free--just chop the axle tubes off the diff, and use the right size schedule 40 or 80 pipe that will slip over them,to join them together,and weld on the spring pads..why haul a differential around for nothing ??...:crazy:
  6. goldwing2000
    goldwing2000 Guest
    For spare parts, as previously mentioned. Better to leave them inside the housing, sloshing around in oil, than to have them bouncing around in the back of a truck getting beat up and rusty.
  7. misterfnygy
    Jan 12, 2006
    199
    Reno
    good idea--
    I like the idea of carrying extra parts back there. I plan to use the trailer to haul the camping gear for extended trips. If worse came to worse I could leave the trailer if I stole all of the parts from it.-- Now I am thinking tandem axle so I can have two full sets:D !!
  8. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    x2
