making 1 3/8's hole in some C channel steel
Discussion in 'The Garage' started by down4thakrown, May 22, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    making better body mounts for the cab and want to put the 70's bushings in the rear.
    is there 1 3/8's inch drill bits out there?????/
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a metal hole saw will work better and faster than a drill bit, cheaper too.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i was thinkin that but theres already a 1/2 inch hole there and i need it to be a 1 3/8s hole
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    How about a hole saw?If you are enlarging an existing hole,you can clamp or tack a piece of metal on the back side of the hole you are working on for the center brill bit to go through.
    Plasma or a torch would be easy too :D
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i could try that, this metal is i think 3/16 or 5/16's
    you guys think the harbor freight hole saw would handle that???
  6. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    Harbor freight saw blades and drill bits suck.It's worth your money to buy a good hole saw.
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Use lots of cutting oil and low RPM.Speed kills hole saws :D
  8. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    how much to decent hole saws and oil go for?? could i get some at Ace hard ware
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i could not find a metal hole saw at HF, i picked up a set of wood ones, they work ok for sheet metal, but anything thicker than 16 guage kills them fast.
    most hardware stores have them for like $7 for the holesaw (depending on size) and $8 for the pilot.
  10. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I use Rapid Tap cutting fluid but pipe thread cutting oil works well also and is cheaper.
    Run the hole saw you have and see what happens.I use Dewalt hole saws that I pick up at Ace and I think they are between 6 or $8 but its been a while :grin:
  11. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
