Making a 79 blazer 100% convertable....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eripley, Oct 20, 2003.
  1. eripley
    eripley 1/2 ton status
    Oct 1, 2003
    145
    knoxville,tennessee
    Here is my plan for when it warms up. Im going to remove my top. However, as you know I still have the cab top since I have a 79. I dont like that as well and want to go full topless. I already figured out where to make the cuts to do it. That way the top removes in two sections and is actually more managable. The back "camper cover" would remove first and then the top cab section last or it could be left on. I was looking around for gaskets to water proof my concept. But then I got to thinking that there are companies that make convertable kits for pickups. I remember a friend in 92 making his toyota low rider a convertable using a kit. It seems harder to do than with the blazer since with the blazer there is no back glass and no seal across the entire back. Back to my point....I got sidetracked... Is there a kit that you have seen for a 79 to have a convertable top like the 73 and earlier? That would be sweet.
    If not I'll just wing it. /forums/images/graemlins/smile.gif:):)
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Right here is the only kit I know of. /forums/images/graemlins/rotfl.gif
  3. eripley
    Oct 1, 2003
    145
    knoxville,tennessee
    Haha..I about died laughing. Yep thats the kit I was thinking of. That and a cutoff wheel.
    However, I thought I would see if there was a kit with instuctions before I started hacking away! Hence the post.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    dear lord, yet another 2nd gen getting its head cut off! meh!!! /forums/images/graemlins/confused.gif
    j
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    No one makes one for a Blazer, but US Body Source makes one for a truck for $800 /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif. If you feel like chopping the back off of a new piece of fiberglass I'm sure it'd work. US Body Source Truck Convertible Cab
    And don't forget that you MUST reinforce the cab before you chop anything or else the A pilar will cave in and the doors won't align properly or even close at all.
  6. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    I'm going to do a very similiar operation to m 80, but what I did is found a 74 body that was hammered and pulled the doors and windshield surround. I'm going to (When I can get my body guys help) cut the cab off at the factory seams and simply (LOL) weld in the 74 windshield surround, and wellah, full top. Then if you want to put an aftermarket cab on, you've already got the stock gaskets. LMC Truck has replacement gaskets and US Body Source has the fiberglass cabs. I just picked up another 74 witht the idea of doing a short wide bed p/u with an extended cab (long wheel base frame) and convertable top. Who knows if it will ever happen... There is a guy that did this and wrote up an article in the tech section of CK5 but I don't have time right now to go find it. I have to go to work. Hope that helps.
    T-roy /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  7. /forums/images/graemlins/1zhelp.gif DOES IT COME WITH INSTRUCTIONS !!
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    my "73" is actually an 87. I bought it partially converted. They guy i got it from actually cut all the spotwelds from the firewall up and changed in a firewall from a 73. A little more work than I would have done! I was just gonna change the upper part of the windsheild frame. I had to "roll" the top of the qtr panels and box them in. not a big deal. I had a set of 73 doors, but sold them and hacked up a set of aftermarket doors. (didn't want to trash original parts when wheeling) You just gotta make sure you reinforce the body. The 73-75's had "rocker boxes" that stiffened up the body. I put a full 10 pt. roll cage in mine, but others have run box steel under the floors inside the rocker panels.
  9. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I think these guys also make a kit for blazers (this is their Bling Bling Ford kit)
    [​IMG] /forums/images/graemlins/grin.gif
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I dig that tape windshield frame cap. "Built not bought" baby! /forums/images/graemlins/crazy.gif
