Making hole in door for electrical wiring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, Aug 20, 2001.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I bought new doors and I need to make a hole in the side of them for the wires to pass through for the windows/locks. I would rather not use a grinder or hole saw because I don't want metal shavings inside the doors. Does anyone have a suggestion on how to make these holes, I think they are 1 to 1 1/4 inch in diamter.
    <P ID="edit"><FONT class="small">Edited by rampage on 08/20/01 12:38 PM.</FONT></P>
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Use a hole saw...but grease the hole saw up so the shavings stick to it.
    Rene
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I think you may be hard pressed to find any way to cut a hole without getting shavings inside the door. You could run a powerful shop vac right next to the bit while drilling and that would help keep most of it out.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Is it a bad thing when my reality check bounces?
  4. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Go find a electrician, or a sheetmetal shop with a "slugbuster" You have to drill a small pilot hole (much less in bottom of door) put the dies on and presto you punch a perfect hole.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  5. rampage
    Mar 20, 2001
    2,261
    73
    I have one of those but it is 3/4 inch and I'm having trouble finding a larger one (or anyone that carries them at all). It was my father's so I don't know where he got it from. Home Depot has them but only in a set which costs $275.
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Look for a local electrical or plumbing supply shop, or bigger Sears stores usually have them too - I've got a 1" Greenlee that I picked up for $17 and change through Wesco. If all else fails, go to Sears and get a Uni-Bit - they tend to throw the chips out the back, and any that go inside the door will be large enough that a quick pass with a magnet will pick them all up.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I may be missing something....but whats the big deal with shavings inside the door? Pop off the plastic panel and vacuum them out.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  8. rampage
    Mar 20, 2001
    2,261
    73
    I don't want to chance metal flakes inside the window motor plus these are new doors that have been painted inside so I don't want metal flakes inside that can start rust forming on them. I'll be cleaning it out afterwards but I'd rather not have flakes if I can help it.
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Another not so recommended method, but one that I've done is a woodworking "chipper" bit - the bit will be toasted after you're done, but there won't be any chips to deal with - it cuts out a nice little plug.
    Dos mas Tecates!!!
  10. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Drill a pilot and then use a step bit or a reamer bit. The reamer will give you one large shaving. The bit will give you a few large shavings. I got my reamer from Grainger. I Think you can get a remer from sears though, same with the step bit.
    * the rearmer looks like a big spinning top from the 20's-50's.
  11. rampage
    Mar 20, 2001
    2,261
    73
    I think I know the tool you're talking about and I beleive that I actually have a few (don't care about ruining it either), so I'll look into that. I also have a Grainger store nearby so I'll check there too. Thanks for the leads.
  12. dyeager535
    26,979
    You don't need a big hole anyway. Remove the plugs from the wiring with a papoerclip. (they are just like most other connectors, a single tab holds each crimped on lead in place in the connector)Once you are dealing with just the wires, you can thread them through.
    You could fit it all in there with about a 1/4" hole. If you are worried about abrasion, use a grommet and cut the hole that size. Bottom of the door has drain holes, use a vacuum and shake the door out good. You are going to get rust no matter what in there, door shavings aren't going to be the catalyst.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  13. rampage
    Mar 20, 2001
    2,261
    73
    That's a good idea. I've lined the bottom of the doors with a spray on rubber liner so any water inside the door has no place to go except out the drain holes in the bottom. Hopefully that'll help with the rust that usually forms on the bottom of the doors.
  14. dyeager535
    26,979
    The problem with rust on the doors is the gaskets. The gaskets hold water against the door after it rains, and you open it up. Rust forms. A good paint barrier here, that is not allowed to wear through, would solve that. As well, the factory "caulk" that they use on the seams, typically cracks, and allows water to get at the unprotected metal. Prevention such as you mentioned, is going to slow down the process, but it's always a good idea to not forget about this stuff, for when you do, after 4-5 years, it's going to be the same problems all over again. I plan on spraying the insides of the doors with POR-15, and not sure what I'm going to do about the lower edge..maybe a small stripe of POR-15, the rest body color.
    Dorian
