making my new 14bff work...
Discussion in 'The Garage' started by muddysub, Dec 15, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ok the spring perches are about 40" (give or take a 1/4") apart. (inside to inside) is that 1 ton or 3/4 ton? will i need new u-bolts and spring plates? i have a 14bsf right now, are the tubes the same diameter? will my rear brake line fit on this one or will i need a new one?
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The tubes are not the same, but as the engineers say, They're "close enough" to use same ubolts and plates. Can't remember about perch measurements though.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You should get new U-bolts couse they streach !!!!! I know some people reuse them, but I get new ones everytime I take mine apart !!!!!!!!!!!!
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'd get some bent and try to use the same plates. /forums/images/graemlins/thumb.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your spring perches are 40" center to center, you'll have to move them out to 42.5
  6. muddysub
    Jun 23, 2001
    10,451
    489
    [/ QUOTE ] they are 40" inside to inside didn't measure center to center, i should have. and i know the bolts stretch, i'm geting new ones anyway cuz i'll be doing my shackle flip when i do the swap so i'll need shorter ones.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If they're 40 inside to inside then you don't need to move them, since they are 2.5" wide so that comes out to 42.5 center to center. </font color>
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I into all of that right now too...I made my own spring plates and have one extra set. I made the extra set to line up mine when I welded them on....let me know if you want to get them... /forums/images/graemlins/rotfl.gif
  9. muddysub
    Jun 23, 2001
    10,451
    489
    i just might. thanks, if i need em i'll buy them.
