making my own HD tie rod
Discussion in 'The Garage' started by Langosta39, May 20, 2003.
  1. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    i was going to make my tie rod with some burly DOM tubing with some nuts welded to the ends to mount the TREs. I was reading 4x4Iron's website and they say that the TREs thread 3 INCHES into the tie rod. How do they do this, and how can I do this? Do they just use tubing that has the perfect I.D. then tap it 3 inches? I would like to figure this out because having the TRE supported all the way in would be way stronger and stiffer than just having 3/4" of thread holding it in. Or would it? Opinions please!
    andy
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    u might drop shane74 a pm about this... he made himself one recently...
    j
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes, 4x4 Iron's Rods are machined 3" deep with threads. Tim cuts the rods to length then sends them to a machinist and has them threaded for the style ends you want. He then cut and welds on another rod to the outside of the first rod if you order a sleeved rod. He just built mine awhile back. It is burly.
    The TRE's thread down deep into the rod for maximum support and strength. He has told me that I might need to knock some casting flash off the end of the TRE's to get my Toe just right because they thread all the way in.
