making my own high steer steering arms: what to use?
Discussion in 'The Garage' started by Seventy4Blazer, Jan 25, 2003.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    k, i can get my own high steer arms made. for free with the exception of cost of material and maybe some drinks.
    i know that the majority of them out there are made of steel. normaly high strength steel. BUT, would T-6 aluminum work for this as well? i know T-6 is strong. but is it strong enough?
    he said he can use ethier but i was just curious if aluminum was used at all. i know that going from one inch of the thickness i normaly see out there to say inch and a .25 would be good.
    any thoughts?
    grant
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I wouldn't trust any steering arm made out of aluminum. The thing would break pretty quickly and put you in a ditch. </font color>
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, thats what i was thinking. but i like to try anything in idea form before it gets past paper. i still got to draw them up and all.
    thanks for the input.
    grant
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well, I'm making mine out of 1.250" Steel so the equivalent alluminum would be like 3" or something. But I'm the master of overkill so...
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeah, there are a lot of places I might use aluminum on a rig... but a steering arm isnt one of them.
    j
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Grant, I work with these materials everyday and this is not the place for you to go to aluminum. It could be done but with 7075-T6 and then you would have to bush the holes with steel or bronze. The cost would be out of sight.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The fatigue life of Aluminum is what knocks it from consideration for a part like this. The number for Aluminum that Engineers use to calculate the fatigue life of a part is excatly half of the number used for steel.
    With the right alloy, like 7075 or perhaps 2024, it could be made to be strong enough. C5 Corvette front uprights are some forged aluminum alloy as are aircraft landing gear struts. Both are overbuilt and the obvious one, in theory, is checked regularly.
    I'd use 1020 steel and use aluminum elsewhere to lighten the load.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My neighbor works at a plant that makes aluminum forgings for some military aircraft landing gear struts. After they're forged they're sent out to be heat treated at a plant that is certified to meet the mil-spec process. Then they undergo a 100% Rockwell hardness test. Having something like that done for a single part would probably exceed the value of my truck. /forums/images/graemlins/wink.gif
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I hear you can get a cool aluminum exhaust tip for a Civic, but that doesn't do us much good. Steering is not a good place to save 3lbs worth of weight. Stick with A-36 or better and accept the weight that comes with it. /forums/images/graemlins/shocked.gif
  10. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I made a few crossover arms and other items. In these applications I used 4150 steel. Lots better than 1018 coldroll.
    This would be a good topic for a metallurgist to steep in.
