Making my own spring perches, is 3/16" wall square tube adequate?
Discussion in 'The Garage' started by mofugly13, Oct 4, 2004.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Making my own spring perches, is 3/16\" wall square tube adequate?
    Title says it all. I have some spare 3" square tube in my garage with 3/16" wall, is that thick enough for spring perches for my D70? Maybe if I cap and weld the ends?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: Making my own spring perches, is 3/16\" wal square tube adequate?
    If you cap the ends it should be good enough.
  3. willy s wagon
    willy s wagon Registered Member
    May 28, 2002
    20
    craig, CO.
    Quick question, do you have three inch
    wide springs,or is it 2 1/2 x 3/16 tube?
    I just did mine last week and I used
    2 1/2 x 1/4 wall so I don't know about
    the thinner wall tube.
  4. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I'm using 3" springs. I have a couple of pieces of 3" square by 3/16" wall by 5" long pieces of tube and would like to be able to use these rather than having to go out and buy the steel-$$$
  5. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Anyone else wanna chime in??
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Your gona be hacking into the tube anyway. Why not add some bracing inside the tube to better hold it together. Wouldn't take much to do and would serve the same as capping the ends just more. I guess I'd use 1/4" wall tube and the steel tube wouldn't cost you much really.
  7. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    OK, 'nuther stupid question, when I hole saw the axle tube radius into these perches, should I do it so that the weld seam will be on the bottom or the top when the perches are installed?
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'd put it on the bottom. This way when you weld it to the axle the fact that it has a seam is pretty much moot.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I put it on the bottom.
    Have fun with that hole saw /forums/images/graemlins/hack.gif
  10. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Re: Making my own spring perches, is 3/16\" wall square tube adequate?
    Stock stuff is no more than 3/16 (I think), but I'd brace it on the inside just to be safe.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Put the weld seam down. 3/16 should be fine but border line for what I would choose. Cap the ends and it should be fine...
