Making some more progress--doubler crossmember PICS!!!!!
Discussion in 'The Garage' started by SCOOBYDANNN, Oct 26, 2005.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    :D Well, i am making some progress on my ScoobyDee. Im 95% happy with the end result of my doubler crossmember but since i used a mucked up piece of my friends cage i shouldnt be complaining. I modified the two existing crossmembers and built around them. (i just used the mounts.) I think i have the cases moved about 3/4" to 1" above stock so I will need to either modify the tranny tunnel or get a 1" body lift. The only thing that hangs down below the frame is the tubing itself, and even then it is about what was hanging down before. the frame rail "bushings" are 1 3/4" tubing capped off w/ 3/8" plate fitted inside the tubing and welded up and smothed out. bolts are 9/16
    frame mounts
    underneith (stock CM modded)
    from top
    what hangs down (and a stupid monkey helpin out) :haha:
    from the back
    whatch guys think?
    Dan
  2. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    looks great! it would be interesting to drive a truck w/ a double to see how its like..
  3. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    looks good, your tube working skills are pretty awesome.. sweet lookin stuff
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Looks good! :thumb:
    Only concern I have is the two front bars that are just cut off straight and capped. May be potential for hang ups. Why not bend them up some like the rears?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Very nice, I like the center bushings. I've been revisiting my cross member design again and again, but can never seem to come up with a design that gives me the clearance I want without hard mounting the case. I like yours much better than what I have now, and the clearance is no worse than what I have now, so I may pay you the "sincerest form of flattery" (i.e. steal your design ;))...
  6. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    steal away---thats what i did, :D i copied one of my friends design. but added some flair. what i like about it is the only thing that hangs down is the pipe, not the cases. once i plate it ill be even better off. floorboards might be an issue, but ill cross that bridge when i get to it. As for ending the front like that----i know, that is why I am 95% happy with it. I built this out of basically scrap and i didnt have enough to finish it off the way i wanted. that and the driveshaft made it relatively difficult tot make it decent. ill see if i cant cover it somehow.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, I would definitely have to modify the front due to my drive shaft and some other ideas I had. But the approach looks really good.
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I like it!.....
    Now you just need some "skiddy" piece of aluminum bolted on there and you be set!
    Don't know how I ever wheeled w/ out a flat belly before! :thinking:
    Marv
  9. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Looks really good!!! Gives me some much needed ideas for mine. :D
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks real good :D
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    that does seem to be the issue... with bushings at the frame though, is it really a big problem if the cases are hardmounted at the crossmember? Do a lot of people break adapters that way or something?
    j
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've seen a fair few breaks attributed to that, more so than square shafts which I've been somewhat derided for using. Frame flex, broken motor mounts, and other inputs have to be dealt with somehow. I prefer a stock style central case mount with stiff motor mounts so that it forms a sort of 3 point mount that the frame twist can not put a stress on trans case twisted between the rear mount and the motor. Likewise, a motor mount that gets “soft” (or worse) won’t torque the assembly. But at the same time that rear mount needs to be able to constrain the torque load of the output shaft to prevent twisting loads on the trans housing from that direction. Probably the best compromise (at least in my current opinion) is stiff poly engine mounts, stiff poly trans mounts in the stock location (allows some flex to deal with frame twisting while still pulling up short on torque loads) and hard mounts outboard at the frame. With probably less than 1/8" or so of MAX deflection using bushings out at the frame rails, that translates to almost NO angular flexibility at the case mount, and I just don't think that's a good thing. But, some people seem to get away with it, just like some seem to get away with square shafts. I'm not so fortunate, so I'll go with the design like Scoob...
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I see what you're saying about the bushings at the frame not allowing as much movement as a centrally-located stock-style bushing. Other than raising the drivetrain up though, how else can one get a completely flat belly?
    j
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I was trying to address that with one of my old designs, but there just was not enough room, so I scrapped it. The post is somewhere in CoG...
  15. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Try cutting board material, it glides real easy.
  16. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    And its probably cheaper and lighter than aluminum too.
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hey Matt, got a good source? I've got to revamp my skid to fit better around my links. Did you find a good way to attach it? Doesn't weld very well from what I can tell... ;)
  18. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    go to onlinemetals.com and go down to the plastics. go to UHMW...its the same stuff used for cutting boards...and many other high strength stuff.
  19. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    I was definately considering this, but how thick do you need it to support our fat arses. someone i know brought up the fact that it would just crack :dunno: .
  20. PsychoticDeadGuy
    Jan 8, 2005
    753
