Making the doors easy to take off.
Discussion in 'The Garage' started by Sandman, Dec 25, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Isnt there a way to modify the door pins or something so that the doors can be removed easier? Who's done this? Thanks.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I have seen someone else remove the hinge pin and install a pull pin before. I think Steve Frisbee did this mod.
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'll have to look at that. Thanks.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup these are mine
  5. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    do they rattle at all?
    how does the original pin come out? /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  6. beater74
    May 29, 2001
    1,749
    atlanta
    no rattle at all i just removed the old pin and welded in some tube to the center section of the hindge the tube has a 3/8 diameter, so them i reemed out the holes on the outer hindge to 3/8. so now all i use is a 3/8" bolt (greased) with a nut to hold it together
  7. TENNJIMMY
    TENNJIMMY Registered Member
    Feb 26, 2001
    6
    TN
    -You can drill out the door hinges with 31/64 bit.
    -Buy door hinge bushings for chryler/dodge. I bought Help- item number 38377 from auto zone
    -use 3/8" x 4" hitch pin for the door hinge pin
    -if you use this it takes a hammer and screw driver to take out the hitch pins
    I do not know how well they work with stock heavy door, but they work great with my canvas doors.
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I think it was last year, someone posted about grinding the knurl down on the hinge pin so they easily slide in and out. Then welding on a washer to the top of the pin. This way you can pull on the pin and they pop-off.
    I did this, and found the top pin would not slide in and out because of the shape of the door. I made the pin slide in from the bottom. I am using a safety wire to hold the pin in though. /forums/images/graemlins/tongue.gif
    I like the bolt idea better...
  9. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    This is the link to my cheesy little drawing....
    Hinge Pins
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    That looks good to me. You just pound out the pins?
  11. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I did exactly that. With the exception of the top pin. I got some longer ford pins (they are the same dia. as the chevy), and drilled holes for a spring pin. I put them in upside down and use a washer and the spring pin to keep them from falling out. Works great! /forums/images/graemlins/thumb.gif It takes me about 3 minutes to take my doors off. Plus when I put them back on, they are automatically lined up to shut right. /forums/images/graemlins/thumb.gif
