man I am finally making progress!
Discussion in 'The Garage' started by solowookie, Apr 13, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    <a target="_blank" href=http://www.vtengineering.com/ck5/DD-Engine-9.jpg>Picture 1</a>
    <a target="_blank" href=http://www.vtengineering.com/ck5/DD-Engine-10.jpg>Picture 2</a>
    <a target="_blank" href=http://www.vtengineering.com/ck5/DD-Engine-11.jpg>Picture 3</a>
    it seems like I have been waiting on this part or that, and I was positive that I had everything ready. well I got a new fuel line to replace the HP fuel line section between the TBI &amp; the frame because the moron that fixed that line (no not me) used rubber hose &amp; hose clamps.
    well I pulled the line to realize the the moron had not only ruined the part between the TBI &amp; frame, but also between the front of the frame &amp; the fuel filter. looks like I will be trying to find that section of line on monday, and down until I can find it.
    I am betting that none of my local dealers will have this part, and the ends are that GM specific non-standard thing. it is a combination of braided line &amp; steel so you have a place with to be able to change the fuel filter.
    I will probably end up replacing it with steel, and then getting the actualy replacement piece in place later when I get it.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Looks good! I see poly bump stops in there too! I'll bet your dying to kick it over!
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    this things been sitting for about 7 months now, and I'm dying! man after I got the $$$ to get the parts together my work started picking up it's been very hard to find time to finish it up.
    I gotta lot of nice stuff on this; 3/4 ton axles with 14B FF rear (including disk breaks), greasables all the way around, disconnect sway bar etc. man this thing sure rides sweet.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Looks great Jeff.. Almost there /forums/images/icons/smile.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Looking good, hope you find the fuel line you need.
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea me too, but I do not think it will be very likely around here /forums/images/icons/frown.gif
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    yup... looks great... just keep poking at it and it will be finished and rolling
  8. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Jeff, looks great!
    Maybe Twiztid (he's north of Salt Lake and works in a shop) could help you find what you need.
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Thanks for the local, Mayor. But, I've had the pleasure of meeting Jeff befrore. /forums/images/icons/smile.gif
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Looks great, Jeff. But I think you might have problems with the No. 1 plug wire routing. [smlie]
    I'm afraid I'm not much help with the fuel line problem, sounds like you probably have a one-off kinda thing, that might be a tral and errror fit/fix.
    BTW, have you given thought to the front drive-line length, I really think it needs to be shortend.
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    good looking powerplant! when is the Grand Firing?/forums/images/icons/smile.gif
  12. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea I have - you found a major problem that day. this thing had a VERY short life after you discovered that when I was down there. if I drive carefully it does not bottum out, but that is something that will be addressed ASAP when I get everything else put together. (but not before I make a fishing trip over to Flaming Gorge /forums/images/icons/wink.gif)
