Man,I'm glad I didn't buy one of these....
Discussion in 'The Garage' started by moneypit, Dec 6, 2005.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    link no good
  3. moneypit
    Sep 3, 2000
    1,382
    COLORADO
  4. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    copy paste the link
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    *appears* to be an NWF piece...any confirmation?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Dayum, thats gotta hurt
  7. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Yep......:doah:
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Looks like maybe the rear case did not have its own mount or something I dunno but it had to hurt.
    Ira
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Looks like the bolts didnt have enough thread engament and it just pulled out the bolts. Then the torque bent the ears of the adapter.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Looks like a combination of the above two posts contributed to the failure. I really don't see much for thread engagement on those bolts. It appears as though the only part that stripped out was the very tip of a couple of them, so maybe they were backed out in the first place. :confused:
  11. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Not sure why 4 bolts would be enough to hold it together:dunno:
  12. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Got lock tight???
  13. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    You're quite correct, the paticular situation with the customer was too short of bolts used and lack of lockwasher/loctite, the parts were replaced without question and overnighted.
    A valid question - but the 4 bolts are enough to retain the adaptor kits together and have worked well for the 95 other adaptor kits in use today.
    Thanks for the concern - we 100% stand behind our products and will continue to do so.
    -Kyle
    NWF.
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    :waytogo: Cool that even though the customer obviously screwed up you replaced the part.
  15. jekquistk5
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    this is why when I find the money tree I will be giving you a call!
    good work :thumb:
  16. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    right awn :waytogo:
    This is another benifit of the multi plate design. NWF just need to send out the plate that broke, not the whole adapter. Maked life easier.
    I really wish I would have held off for one now (and the bling alloy D60 arm).
  17. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    194
    Colorado
    It still appears that you only get about 3/8" to max 1/2" thread engagement into the 205 plate. With the Correct length bolts how much thread engagment do you get?
    With only four bolts producing the clamping force this seems a little lite IMO.
    Way to go with the Customer service.
