Man this sucks *UPDATED* HELP!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by LKJR, Apr 11, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    well after sitting since last september with what seemed like everything going wrong I got to drive the blazer yesterday for a short bit. BUT the part that sucks is I"ve put the tranny tunnel cover back in and my tcase wont go into 4low. I guess I've got the drivers side most shift rail pulled out a little too far. so hopefully tommorrow I can get a prybar in there and help negotiate it back. But all that's left I think is to replace the filler hose and vent and weld the floor pans back in.
    YEA HAW, finally
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    Re: Man this sucks
    Ok Teach me. Is there a removable tranny tunnel cover or do you have to cut it out and weld it back in? I have pulled tranny, engine, and transfer a few times and just struggled with the top bell housing bolts.
    Thanks for the info!
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Man this sucks
    It bolts in. Bet you wish you knew that sooner.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Re: Man this sucks
    get your gastank fixed?
  5. 70jimmy
    Mar 3, 2000
    5,961
    251
    Re: Man this sucks
    Doh! That would have saved some cuss words and some beer!!
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Re: Man this sucks
    Well, it's all back together, took the shifter off today and did a little tappyidy tap tap on the shift rail and it went all the way back into 4 low. Then when I put the shifter back on it wouldn't pull out very easy. finally it yanked out so I'm back to just 2 hi and 4 hi, no N or 4 low. My shifter is loose, (plastic bushing is missing, and bolt is now bent slightly, I don't have the greasable one) Would this be the cause of it not shifting? or is there something I"m missing here? I was pretty careful when I put the case back together after the rebuild, so it should all be in right, especially considering I tapped the rail with a hammer and it went in pretty easy. If I have to replace the shifter I might as well go with the dual shifter setup. But my fab abilities around here are very limited considering I"m 350 miles from home where I know people.
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Re: Man this sucks
    Les,
    I can't recall....do you have a body lift, or have you "shimmed down" the xfer case?
    On my truck, since it has a body lift...the shifter opening is NOT large enough to allow me to select all the gears...specifically I couldn't get 4LO.
    There is a chance that you have a "physical interference" between the shift lever and the tunnel sheetmetal (or the trim ring for the shifter boot) that's keeping you out of the forward-most lever positions.....
    MAYBE? /forums/images/icons/crazy.gif
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Re: Man this sucks
    nope no lift and the boot is off, the shifter is loose, that's all I can figure either that or I have something inside not working right but I was careful on reassembly so it should be fine it's only the top shift rail giving me problems. No body lift yet
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Re: Man this sucks
    if it went with the hammer it might be the plastic bushing. its just in enough of a bind to where it wont go. see if you can wrap it in electrical tape or something so that its snug. maybe that'll help
    nathan
