Mandrel Bent - Worth it??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, Apr 17, 2000.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I can get a local shop to make a custom exhaust for my Blazer that will fit exactly the way I want it to. The only thing is that it won't be mandrel bent. Does mandrel bending really make that much difference to rear wheel HP & torque in a cat-back exhaust and could I just go up a 1/4"-1/2" in diameter size of pipe to accomodate the bends? I figure it will be alot cheaper to get a local exhaust with a good muffler (like Flowmaster) rather than pay hundreds of dollars for mandrel bent pipes that will rust just as fast!
    Brian
    Still in search of the TBI KING!!
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    you could step it up 1/4" or 1/2" if you wanted, however, you don't need to do that or the mandrel bends unless you have a high horsepower engine that really needs to breath. I have an '89 f/s Jimmy with dual 2 1/2" pipes running through flowmasters... it sounds great!
    NEVER been stuck... *yet*
  3. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    What does "mandrel bent" mean?
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  4. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    it means that when the pipe is bent, it doesn't divit it were it was bent. Mandrel keeps the o.d. of the pipe after being bent.
