Manifold bolts?
Discussion in 'The Garage' started by BlitzK5, Oct 21, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I just pulled my manifolds off my 454 to re-tap the threads on the collector. The bolt used to connect the manifolds to the engine look like just any old grade 5 bolt, and there shot. Are regular grade 5 bolts suppose to be used or are there special type of bolts needed due to the heat. Aslo since I got them off should I upgrade to headers or is there not much point for a 454?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive used regular bolts. Just stay away from nuts with the nylon lock crap in 'em. Those will melt and ooze out. If you got the Green To Make The Scene, I would definatelly get Headers. Just also buy some quality gaskets, and know that you will have to occasionally check and tighten the bolts to prevent leaks. Help improve your motor's efficiency...
  3. BlitzK5
    Jul 29, 2005
    288
    opps sorry I ment the manifold bolts use to connect the manifold to the heads. My bad should have read my question. I will Edit it.
