Manifold vacuum for booster, please help
Discussion in 'The Garage' started by avgas, Apr 24, 2004.
  1. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    I'm trying to switch my k5 back to a quadrajet. But the quadrajet does not have a vacuum fitting on the back for the booster like the edelbrock I am replacing. Will it work to T-off from the vacumm fitting on the manifold that supplies vacuum for the transmission and the heater???
    Anyone else ever come accross any problems like this?
    -jake
  2. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I know on the Edelbrock manifold there is a threaded port behind the carb for a vac booster fitting.
    /forums/images/graemlins/usaflag.gif
  3. avgas
    Jun 5, 2003
    179
    Renton, WA
    yeah thats what I have, but prior to now it just had tranny and heater vacumm lines going to it, so I guess it would probably be ok to T-off somehow and relocate my brake boster to there.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its not a problem at all, the carb was just from a non power brake vehicle is all if there is not even a threaded plug threaded in the rear center of carb base
    yes anywhere on intake or in base of carb will work, it is all intake vacuum same
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Unthread the adapter fitting for the booster hard line from the back of the Edelbrock, thread it onto quadrajet , and you should be fine. I had my friends Edelbrock on my truck for awhile while I waited for my Quadrajet and the adapter threaded right on . /forums/images/graemlins/k5.gif
