Manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85Jimmy, May 25, 2002.
  1. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    Which intake manifold is best for the $ on a sb chev? weiand stealth, weiand action+, edl performer, performer rpm, or the new performer eps. Thanks- Chris
  2. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i've run edelbrock performers on damn near everything i've own and love them.just my 2 cents
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've always had good runnin with edelbrock too, going with the performer on my 400 build up next.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    performer. to me there is no ? about it. i have always had great performance out of mine and it is ver nice to the wallet compaired to the rest.
    grant
  5. 85Jimmy
    Oct 30, 2001
    97
    Which performer would be the best the E.P.S. the R.P.M. or just the plain performer? Thanks- Chris
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i have the regular performer. if you have egr get that one. just to keep it easy when it comes time for inspection.
    grant
  7. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i have the weiand stealth on my nova. it was recommended to me since it has a broader RPM range. i think the edelbrock one is idle to 5500 RPM (??), but was told it starts dropping off at 5000 RPM, whereas the stealth is idle to 6000 RPM (?), it is a good intake. i seriously doubt you'd be revving up your truck motor to 5500-6000 RPMS anyway!! /forums/images/icons/wink.gif
    oh, if you chose the edelbrock intake, you'd probably want the EPS or regular Performer series (you might want to check into the Air Gap, but might have to check for hood clearance?). also, the RPM series moves the RPM range higher (1500-6500 RPM)
  8. dyeager535
    26,978
    EPS looks cool I guess...not MUCH gain, but if its the same cost and has the same features (EGR, etc) as the regular Performer, why not?
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If you are concerned about emissions, you will need an EGR model. I think the regular Performer is the only one with that setup (of the Edelbrocks). If you are not concerned with emissions, I would go with the Performer Air Gap. it keeps things cooler and looks cool too (although it holds mud!). The RPM model is more specific to higher RPMs. Our rigs usually need more low-end grunt.
  10. 85Jimmy
    Oct 30, 2001
    97
    I don't care about the egr or any smog crap its allready all gone. Has anyone tried the e.p.s.? Thanks- Chris
