Manual -> Auto Rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Feb 6, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    How hard is it to convert from manual to automatic rear window? Pricey? Thanks
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
    6"Springs, Tranny, & Engine coming soon.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm glad you brought this up! It seamed to me last time I saw this that everyone was so PO'd at their poorly made broken stock electric rear window motor but I don't care, I want an electric one!
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  3. dyeager535
    26,982
    191
    It's either broken handles on the manuals, or slow to roll up power windows : )
    take the "guts" out of a power tailgate truck, and the associated wiring along the frame and up into the cab (along with the switch) and you should be in business.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    ok thanks guys
    87 Custom Deluxe
    305/Sm465/ NP208
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    well, mines suppose to be automatic, but its manual-
    I think this may be a "grass is greener" type thing.. I for one don't know of any K5 that hasnt had some sort of problem with its back window..
    Brandy
    LOVING the new Duramax!!!
  6. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    the auto one that i have i busted, the regulator arms are bent and the motor is burnt or sumthing so i'm gonna go the cheap and get the manual.
    hola
  7. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    If your handle works after you take it out, i would love to get it from you. Because i am damn tired of taping the switch down and getting out to assist the window up.
    DUKE
    Why go around when you can go over?
    <a target="_blank" href=http://http://student.fortlewis.edu/~rdgebhardt/>http://http://student.fortlewis.edu/~rdgebhardt/</a>
    85 K5 <font color=blue>Big Blue</font color=blue>
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Is your key-switch in the gate broken too? One thing that can help if you haven't given up completly is a new cable (runs from the motor to the regulator). It makes a 180° turn and it gets hard to turn the cable with age.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  9. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    your right the key switch is broken. And yes, i have more or less given up on the bloody thing. Unless the cable falls outa the sky im not taking that d#$m tailgate apart unless it is the last time for sure!
    DUKE
  10. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I converted mine recently from manual to power...LOVE the swap wouldn't trade it for anything...I just robbed the parts out of another blazer tailgate cleaned them well replaced worn parts with newer ones and had the rear key switch rekeyed to my current door key...everything works fine I still haven't mounted the switch in the dash plate because I want to take my time...its just laying on the floor for now. I have the wiring diagram that I made up when you get ready to do this project.
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
