Manual Chokes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Jimmyish, Sep 10, 2001.
  1. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    I've got a manual choke in my truck. Is there any advantage to that if I know how to use it, or should I just switch to electric?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Manual is just as good as electric - with the added bonus that you know damned well if it's completely open or closed.
    Clean up on aisle 3!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I used to have one on mine but the end of the cable broke off. It only worked for a while but when it worked, it worked great.
    <font color=red>"Maybe you could drive better with that cell phone up your azz?!!!"</font color=red>
  4. 78Jimmyish
    Jul 28, 2001
    137
    Rhode Island
    Any tips on usage you could give me?
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Choke, who needs a choke? I took my choke out of my firebird(just the choke flap) because I found out it robbed 2.5 real wheel hp. I just hold the idle up a little bit when its cold.(I know it doesnt reaally get cold here, but a high horsepower car doesnt like cold weather.)
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    how would i go about hooking up a manual choke to a 73 q-jet that had one of the manafold mounted chokes? Should i just buy one of the generic choke cables and run it to my dash?
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  7. dyeager535
    26,978
    Is the factory choke stuff missing? I have yet to see a need to replace the same setup on the '74 Q-jet I'm running with no problems now....
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  8. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    I have vortec heads and the manifold doesnt have a provision for mounting a choke
  9. dyeager535
    26,978
    Ahh yes..I will be tackling this myself. (apparently way in th efuture, whenever my block is done!)
    I've decided I am going to have to run a later electric choke version Q-jet. Not really happy about it, because that means I have to tee in an oil pressure switch and wire the choke (not that bad I guess) to make it work right.
    Besides, all the Chev Q-jets with electric choke I have are 800CFM units, and I don't want to hurt fuel economy. (since the extra 50 CFM is made up on the primary side, where you will see it)
    Personally, I don't like drilling more holes and such in my truck than I have to, so manual choke is out in my case. Besides, set correctly, I am very happy with the factory choke.
    I'm assuming (hoping) you are running the E-brock performer intake? If so, how did your fuel line bolt up? I want to keep the steel line thats on the truck now, But I'm not sure that the E-brock is going to place the carb in exactly the same spot....
    Dorian
  10. 78Jimmyish
    Jul 28, 2001
    137
    Rhode Island
    What kind of tips can you guys give me for making my manual choke work for me. How do I use it most effectively?
  11. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Well the fuel line on my truck had been cut about where the manifold sits and a rubber hose is between there and the inlet on the carb so all i had to do was get a little bit longer piece of hose. i put a performer intake on a friends truck and he had the complete fuel line still and it hooked up allright.
  12. Chief Brody
    Chief Brody Chief of Amity Police Premium Member GMOTM Winner
    May 18, 2010
    7,636
    297
    Alabama
    Trying to remove instrument cluster and dash cover...what is holding the manual choke lever in place?
