Manual Clutch and Body Lift?
Discussion in 'The Garage' started by skyyk5, Mar 8, 2007.
  1. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    Has anyone had any troubles with a manual clutch and a 3" body lift? I might need to get the truck going fast. Would go hydro, But have all the linkage parts already.
  2. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    i had a 2 inch body lift on my truck and all i done was cut the rod in half and added a 2 inch section to it
  3. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    I put a 3" on a K10 but I used threaded rod & an adjustable turnbuckle. I had to lengthen the hole in the floor pan for the clutch rod.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I couldn't go anymore than 2" or it would bind, and I also had to cut a slightly larger hole for the rod. But otherwise the linkage is stock...
  5. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Like these guys said, lengthen the rod and move the hole in the floor back some.
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I'll try that! Thanks all.
