Manual Clutch Pedal Spring??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Burt4x4, May 29, 2004.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    So what is the easiest way to remove that big spring on the clutch pedal? Should I just remove the spring studs? That spring is perrty damn stiff and I don't have any leverage under the dash??? /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    tie a wire around one end and pull or use some vice-grips. carefull with the vice grips if you clamp too hard they may kink the spring.
    /forums/images/graemlins/thumb.gif
    ARQ.
  3. Burt4x4
    6,854
    Thanks, I got it off /forums/images/graemlins/thumb.gif
    So it would look like that spring is not needed with hydro?
    Did you toss yours Arq?
    That master cylinder shaft seams to have a very stiff spring. /forums/images/graemlins/ears.gif
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I left mine in place, just remember to adjust your bump stop or the master cylinder push rod will pop out when the pedal is let go. I took out the rubber piece and stuck a hood bumper (the one on the left).
    ARQ.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ive removed a couple, theres a bracket that unbolts that holds the spring in place its simple, then put the tow bolts into the clutch pedal arm back in and all done, its alot better iwthoutt he stupid spring, for sure
    good luck
