Manual Clutch with 3" BL...
Discussion in 'The Garage' started by Confedneck79K30, Jan 14, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    anyone running the setup ? cut a new hole in the floor? lengthen the linkage and bend it for the diff? wont go hydro, ill take the BL out first....
  2. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ttt anyone? if not im yankin the BL this weekend...
  3. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I just finished hooking my up on a 72, had to lengthen hte firewall hole. The shaft was lengthed already. Its not hard to do, just be patient with it.
  4. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Years ago I had a body lift on a manual tranny truck--I just lengthened the rod from pedal to the "Z" bar (on the frame) the same amount of body lift, and re-adjust your clutch; then you're good to go.
    Jimbo
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    is it more likely to seperate when twisted with the bl?
