Manual glow plug controller....need some help with this
Discussion in '1982-Present GM Diesel' started by 84CUCV, Jan 4, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I know very little about wireing. My cucv m1009 i have had nothing but problems with as some of you might know. Well, of corse i thought it was fixed and the same problem comes back. So i would like to go past the cucvs wiring and use Manual glow plug controller. Sounds like the way to go. So can anyone give a good way to go about this? As always thanks for the help
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    Well I just have a 70's ford starter solenoid in my system, glowplug wires on 1 side, batt wire on other, button in the dash going to the switching terminal. works great.
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't know the correct way to do it, but you just need to run power from the terminal closest to the large terminal which has the orange wires coming off of it (the latter is the terminal which points to the back of the truck).
    thus, if you put a push button connection between them, you're set. :)
    i understand there's a blue wire somewhere which can be grounded using a push button and this will work... this is the correct way, i think. i could never find said blue wire myself, but then my wiring is a rats nest thanks to the PO.
  4. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    The elusive blue wire..
    The blue wire you need to ground to activate the glow plug relay is located in a two prong plug on top of the glow plug relay..just strip off some insulation and add another wire to it,don't dissconnect it..run that wire to a push button switch,and ground the other terminal on the switch..
    That is how I by-passed my 82 K20's glow plug controller--I also pulled the connector off the controller and taped it up to keep moisture out,so there was no way the glow plugs could come on automatically again.
    It might be wired differently on military trucks ,I haven't had any experience with those that are 24V...you may need to do like K204dr did on those types of trucks..:crazy:
  5. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Ok so I run a wire off the blue wire to a switch then to the ground? And that turns the glowplugs on? When you do that does the light in the dash come on?
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Yes, the light comes on as long as the button is pushed.
    I use the seat belt light as my timer, it stays on about 8 or 9 seconds.
    Rene
  7. protechk5
    Sep 26, 2004
    2,015
    VA
    Alright, this isnt the relay is it?
  8. k204dr
    Aug 27, 2004
    463
    TN
    no thats just the power junction on the firewall. the relay is probably on the engine, sorta below that. it could also be on the inner fender on the driver side.
  9. protechk5
    Sep 26, 2004
    2,015
    VA
    yeah i found it, and i tapped in to the blue wire, I can hear them turn on but the wait light doesnt come on
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thx guys think i got it. thx i will give this a try.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    can i do this with the 12/24v set up? is it the same? thx
  12. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    yes, he is doing it on a cucv. I have my cucv set up the same way. when you hit the button the wait light is not suppose to come on. but the wait ligth will function as normal. just hold the button until the light goes out and then release and start the truck.
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    ok great thanks
