manual hub installation please help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cr1028, Apr 24, 2001.
  1. Cr1028
    Cr1028 Registered Member
    Nov 26, 2000
    28
    What do I do after removing the spring? I see two clips inside, do I pry them apart? Any help is appreciated
    81 K5<P ID="edit"><FONT SIZE=-1>Edited by Cr1028 on 04/25/01 06:04 PM (server time).</FONT></P>
  2. Cr1028
    Nov 26, 2000
    28
    Re: manual hub installation
    I am removing the auto hub on an 81 K5 right now
    81 K5
  3. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Just did this... pull out the clip, take some needle nose pliers and squeeze the retaining ring( spring) tabs towards one another while gently pulling out on the hub. May have to rotate and giggle ,but comes right out!
    If you have pulled apart the hub assembly(is that the spring you are talking about?), I'm laughing ... did that when I first got my truck. Took me hours to figure out how to put it back together! Don't need to do that ... if you did, discard and work on the retaining clip (ring right at the lip of the hub/rotor), and pull the rest of the hub out.
  4. Cr1028
    Nov 26, 2000
    28
    I removed the outside clip and thats what popped the spring off, now I'm lost because there are two clip looking things on opposite sides in there, I tried prying them apart and pushing them together, I even tried pulling the clips out and I could not get it loose
    81 K5<P ID="edit"><FONT SIZE=-1>Edited by Cr1028 on 04/24/01 09:40 PM (server time).</FONT></P>
  5. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I found exactly what you need. I wish I had this when I did mine. Look at this site and then click on "see the instalation" Hope this helpes. You will get it done and look back and say $hit how could it have taken me that long I should have thought of that. Good Luck, if you need more help just make a post or email me. I'll do my best.
    http://www.4x4review.com/products/drive_train/mile_marker_install.asp
    Sergio
    surg7498@yahoo.com
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Clickable:
    <A target="_blank" HREF=http://www.4x4review.com/products/drive_train/mile_marker_install.asp>http://www.4x4review.com/products/drive_train/mile_marker_install.asp</A>
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> You won't regret changing your hubs over ! One of the best things I've done to my trucks !
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  8. Cr1028
    Nov 26, 2000
    28
    I haven't done anything with a snap ring, where would that be, I've unscrewed the cap, removed the ring about a half inch in from the end of the hub that holds the spring on, spring came off, now I've been told to push the two clips together and pull, I've been using 2 screwdrivers because the needlenose do not open wide enough to get both clips, anyone know what my problem is? Thanks in advance
    81 K5
  9. surg82k5
    Feb 7, 2001
    416
    San Antonio,Texas
    the tool that you need to use is pliers that are specifically designed for snap rings. i think they are called snap ring pliers. you can find them at nearly any auto parts place for probably about 10 bucks. if i am remembering correctly i think you can see the end of the axle shaft. i think the snap ring is touching the shat, but inside the locking washers. You will need the snap ring pliers to close the snap ring inorder to take it off. i think onw thing that would help if you havn't already done it is to clean the insed of the hub where you are working very good. you might just not be seeing it. i hope this helps. if you could describe what you are seeing or take some pics. good luck
    sergio
  10. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Just did mine today [​IMG][​IMG] Easy....took me 10 min's and 3 beers!!!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
