Manual HUB Removal HELL!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Mar 29, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I am having major problems removing my hubs from the rotor. You see last time I removed them the hex heads on those long skinny bolts that hold the hubs on were beginning to strip....now it seems beyond hope to get them out. Any ideas? Whats your trick?
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Easy outs? That sucks though... maybe you should have replaced them before, huh?!!! Good luck! /forums/images/icons/smile.gif
    -Dan
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    cut a straight line throught the head with a dremel and use a flat head screwdriver ??
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Hmmmm I'm thinking BFH time! /forums/images/icons/smile.gif
  5. dyeager535
    26,982
    191
    Last time someone had this problem, I suggested they use a large drill bit to drill the heads completely off, then pull the hub "ring" off, and turn the remaining length out with Vise Grips.
    I think Torx would be good replacement bolts for those..
  6. BowtieBlazer
    Jul 15, 2001
    2,462
    any idea where to find replacement hex heads?
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hit up the hardware store with part in hand..
  8. dyeager535
    26,982
    191
    That length, probably only at a nut and bolt supply house, or GM. GM probably no more expensive. Still think Torx is the best replacement.
  9. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Tractor supply....? They seem to have parts and things like that I can't find at the hardware store but they got em! /forums/images/icons/smile.gif
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    Re: Manual HUB Removal HELL! *Update*
    Thanks all....I am gonna drill the remaining ones out and then worry about replacing them.... I figure hardware store or junkyard at worst case go pull some off another trucks hubs...
    ******Update*******
    Drilling them out worked like a charm. Its alright about the hub bolts for now I expect down time atleaset through monday anyway as I tear apart my rear axle and replace berings and seals and such.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    isnt Warn the OEM supplier?
    if you have no luck at a industrial parts supply house, and you should be able to get those screws there, try a Warn $mall part$ kit
  12. BowtieBlazer
    Jul 15, 2001
    2,462
    They are actually Mile Marker Hubs...which suck...I need to go ahead and invest in some WARN hubs!
  13. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You should be able to go to any 4x4 shop or diff shop and they'll have the "bolt" kit. I bought some replacement screws/bolts from Ace hardware. Good Luck.
