manual hubs, and front axle removal. HELP !!!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ducati-cooter, Apr 14, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    ok, I qam having a makor brain fade now that it is nice here.
    I need to remove my worn out front bearings, problem I can't figure out how. The truck came with warran standard hubs, i removed the cap with the 6 bolts and the notched ring and spring, then I don't see anything else to remove. PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    oh ya the hubs were packed with grease, fun fun
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Did you remove the big circle clip that goes inside the hub? You need a dental pick or something like that.
  3. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    i don't see a c clip in there but there is so much damn grease I have spent the last 1/2 hour cleaning them out, no clip yet
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It doesn't look like a clip. It looks like a piece of metal coat hanger that runs around the inside wall of the hub houseing. I use an eyeglass screwdriver and a set of needle nose pliers to get it out. You have to get something under the clip, and get it out of the gap it fits into.
    Clean the grease , and run your finger from where the locking hub cover used to be on the inside of the housing it sits in toward the internal body of the hub. You should find the clip along the outside wall of near the internal part of the hub that is still in there.
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thanks for the back up, I was seriously dain bramaged this morning. I woke up at 4 AM and took a Benadryl. That stuff should be illegal!!!
