manual hubs!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Feb 7, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    im so excited im getting my 4wd fixed today!! /forums/images/graemlins/k5.gif u know how hard it is to not go 4wheelin cuz its broke? im getting some warn manual hubs as we speak! quick question do i need any kind of adapter to put them in or anything??
    thanks!
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    only if you auto hubs are held in with 5 bolts. if they're 6 then your good to go.
  3. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    dang..i just went out and counted them on the hubs..there is 5 bolts..so what should i do?
    /forums/images/graemlins/crazy.gif
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    nevermind. i just went to warn site and re-read. its 3 hole auto hubs.
    go warn.com
    H. When replacing automatic 3 hole cap screw hubs with manual hubs, you must purchase corresponding spindle nut conversion kit per application chart.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should be fine. Just make sure when you pull out your auto hub body to get that back axleshaft snapring (behind the hub body, not the one infront) out of there, otherwise the new hubs wont fit in.
