manual hydraulic pipe bender?
Discussion in 'The Garage' started by chops76, Oct 16, 2005.
  1. chops76
    chops76 Registered Member
    May 6, 2005
    38
    south elgin, il
    anybody got some advice on how well these manual hydraulic pipe benders work out? i am planning on building a complete exterior skeleton, roll cage and bull bar for my 1976 blazer...plan on bending up to 2 1/2" schd. 40 pipe..i am looking at a 16 ton bender with 7 differnt die sizes for under $100.00..what'cha think?thanks :confused:
  2. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I think 2.5" pipe is ridiculous, and those $100 benders are money wasted.
    I'd recomend HREW tubing in the 1.75"-2" size and a 'proper' tubing bender. DOM is cool too, but a fair chunk more money.
    Rene
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Wow, that would be a HEAVY cage!!! Go w/ the Tubing that was recommended and spend a few more bucks, but save some weight and make your life a little easier in the long run.
  4. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
  5. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
  6. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    It wasn't a specific brand recomendation...more an example. Not that there is anything wrong with the JD2, it's the brand I have and I'm quite happy with it.
    Pro-tools 105 is another similar bender.
    Rene
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Don't waste your $$ on the pipe bender. Ask me how I know. :doah:
  8. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    the best manual tube bender i have seen is the JMR bender. it has a gear reduction drive on it. you can bend tube with a 3/8's retchet with a 3/4 socket on it. saw it at the OFF ROAD EXPO last weekend. a tool could be made out of a 3/8 3in long extension where you cut off the female end, mill three flats on the shank so it wont spin in the chuck of a 1/2 capacity hi torq low rpm drill motor. then you could bend tube with ease. they clain there bender bends 2in .120 wall cromoly and 1 1/2 in .25 wall cromoly with ease. that i AM a tad skepticle of but at the show the guy had a piece of 1 1/2 tube that bent with the ratchet very easy. i have the M-TECH manual bender, it works fine, but i will convert it to hydro when i can afford to. just my .02 cents.
  9. chops76
    May 6, 2005
    38
    south elgin, il
    thanx for you replies and info
    i guess i wasnt as detailed as i should have been.. i was planning on bending up to 2 1/2'' SCHD 40 but it wasnt for the truck, that is just the size of pipe i need to bend for some ornamental side jobs that i do. i will look into these other benders and see what i can come up with..thanks
  10. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    a good manual tube bender can be had for about $400 with die. That's a big chunk of change, with the four dies I have I'm over $1200. BUT, think of the cost of the tubing, you'll spend more on that in a short time frame than on the bender so might as well get a good bender. I would not suggest any of the pipe benders like Harbor Freight or similar, I have used them and seen them used to make some pretty funky rollbars that I would not trust. Kinks, splits, etc. are very common with those, they simply crush the tube (or pipe), rather than draw it through a die
    I bought my JD2 from Medford Tool Supply
