Manual linkage vs hydro clutch pedal sleds
Discussion in 'The Garage' started by GMCLegacy, Jan 28, 2004.
  1. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    is there is different in the pedals used between the mechinical linkage vs the hydro setup on a sm465?
    if there is, can i just swap out the clutch pedal, or do i have to find a whole clutch sled assembly?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    To do it correctly you need the whole assembly.
    Yes there is a difference.
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    there is a difference but i just swapped the brake pedal, no adverse effects yet. Let me clarify, I swapped the manual linkage brake pedal to the hydro setup, as the brake pedal used a diff attachment to the master cylinder, it was the least headache thing to do.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i dont agree with that statement. it was the less headache thing to do...
    its not to much work in my eyes to pull the master cyl. and booster for the brakes and then 2 more bolts off the steering column.
    6 bolts, 4 screws and a few extra min. you get a lot more by using the complete hydro assembly.
    its worth it.
    Grant
  5. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    sorry guys/gals, i think i may have not typed my question as clearly as i could have. i am looking to go a hydro clutch setup, i think it got confused converting from manual brakes to a hydroboost.
  6. dyeager535
    26,976
    Yeah, he did get confused. /forums/images/graemlins/smile.gif
    The hydraulic clutch pedal "housing" uses support rods that also hold the master cylinder for the clutch, (studs on the end of them poke through the firewall into the engine bay) which the mechanical setup doesn't have. I can't comment about whether you can just swap pedals, I'd bet yes knowing GM, but (at a minimum) you'd be lacking the support rods for the master cylinder.
