Manual Locking Hubs for a 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Oct 21, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I just acquited a 3/4 ton 10 bolt. What I need to know is if my 1/2 ton manual Warn lockout hubs will work on the 3/4 ton 10 bolt. The 3/4 ton 10 bolt I just bought has auto locking hubs and I really don't want to fork $65 over for a new set.
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    i think the 1/2 tons were internal mount and the 3/4 tons are external mount, not sure though
    <font color=red> It's not what you drive, it's how you drive it</font color=red>
    1986 K20 & Lots of Rust
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    This is true until about 77.
    Auto hubs indicate the internal mount style, so yes they will interchange.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    sweet
    in that case I might just part out this 10 bolt then
    89 K5 Silverado
  5. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    10 bolts are exactly the same all years ,same hubs etc.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
  6. RedDwarf
    May 9, 2001
    816
    You're right. Good catch. It was the 3/4 Dana 44's that had the external mount since they were the only front available before 78.
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have noticed one problem with using internal D44 hubs on a 10-bolt axle. I had Warn Premiums on my 6-lug D44. When I went to 8-lug 10-bolt, the hubs would not work because the groove in the splines for the locking clip (circlip, whatever it's called, it goes around the diamter of the axleshaft to hold the hub in) was a good 1/2 or inch deeper. So it wouldn't work
    I had to replace my steering ujoints anyway, so I used the outer stub axles from my d44 and tossed the original 10-botl stubs and it went together fine.
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
