Manual locking hubs on 1987 3/4-ton Suburban
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by airheadpilot, Aug 23, 2004.
  1. airheadpilot
    airheadpilot Registered Member
    Aug 23, 2004
    19
    My apologies for the naivety of my post - I'm mechanically savvy and active in the motorcycle world, but I just recently acquired my first Burb and I'm slowly learning the joys of 4x4 maintenance.
    Today's question: My automatic locking are broken (the PO actually removed most of the internals) and thus I can't engage 4wd. I'd like to install new manually locking hubs and would like some guidance. I presume Warn hubs are the way to go? What is the best source? Is it a simple swap, or do I need a special conversion kit? Easy or difficult job? Any special tools? My truck is a 1987 GMC Suburban 2500 with the 350 TBI engine and 3-speed transmission. I presume that means that the front axle is the Dana 60, but I don't know that for a fact.
    Thanks!
    Andrew in Belmont, CA
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Your front axle is a 10 bolt.
    Just remove the auto hubs and install a set of locking ones.
    I haven't had much luck with warn hubs, I will prolly get a set of Mile Marker lockouts for my next set.
    A pick, small set of snap ring pliers and a torx bit is all that is usualy needed to replace hubs.
  3. dyeager535
    26,975
    Factory Spicer Manual Hubs work well IMO, and if you like wrecking yard searching, would be the way to go. /forums/images/graemlins/smile.gif
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I'd say if you go new try the milemarker supreme's with stainless jacket. I have used these on two different trucks for over four years. They work great and are easy to turn.
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Check Ebay, you can buy some Warn premiums on there really reasonable. In fact I have a set i'll sell you for $40 + the ride.
  6. jon v
    jon v Registered Member
    Jul 8, 2004
    22
    Hesperia, CA, USA
    I've found Superwinch hubs to be very good.
  7. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    I'll take em!! are they new?
  8. airheadpilot
    Aug 23, 2004
    19
    Thanks all. I ended up going with the Mile Marker stainless steel premium hubs. Very easy to install and a real quality product. I was a little concerned initially when I reached down to feel them and found them to be quite hot to the touch. However, after feeling them each time I stopped I noticed that they were cool if I had been doing lots of freeway driving with minimal braking, and hot if I had been around town or going downhill on a twisty road where I need my brakes a lot. Figure that it's the brake heat from the rotors being transmitted through the hubs to the lockers. Never so hot that I can't stand to touch them, so I'm sure it's okay. Thanks for the advice all - I'm off-road capable once again!
    Regards,
    Andrew /forums/images/graemlins/burb.gif
