Manual or auto?
Discussion in 'The Garage' started by RingMaster4x4, Jul 14, 2004.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Ok well my blazer has eaten its 4TH TH350 Trans, and now I am thinking about a SM465. I do mostly mud, street no big rocks and a little trail. I have not driven a 4x4 with a manual so I am just wanting to know what others think. A TH400 is not do able right know so it has to be the same length as a TH350, NP205.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I run a SM465 in mine and all it ever does is street and mud. I have found that the clutch gets real sloppy after a while in the mud but it clears up pretty fast.
    I would suggest a tach though as you never know what your RPM's are when you are pounding through a hole in 1st gear.
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Thanks for the input. /forums/images/graemlins/thumb.gif I already have a tach. /forums/images/graemlins/thumb.gif
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Don't you know that big blocks eat Th350's for breakfast...and lund..oh yeah..dinner too
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    yeah but that is what I had. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/dunno.gif
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Manual...period. Cheaper and more durable. /forums/images/graemlins/waytogo.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Nothing says "I'm a hardcore, gear jammin, steel-belted badass" than rowing your own gears.. /forums/images/graemlins/peace.gif /forums/images/graemlins/grin.gif
  8. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Well, I'm in your boat right now as well. I'm an auto guy and have had TH400's forever but I just can't afford them anymore so I'm going with a 4spd on my K5 project. I prefer the auto, since I primarily run mud (for me) it's more fun and easier - plus I like to hot rod it on the street a bit. /forums/images/graemlins/rolleyes.gif
    Anyway, I have had my tranny built locally by friends and even sent it off twice for high dollar professional builds and it's broke again. I simply don't want to spend several hundred dollars on it every couple of years and, call me old and fat, I just don't want to be pulling the tranny any more than I have to. /forums/images/graemlins/doah.gif Plain and simple the 4spd is more durable so I'm going that route for a while.
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I have always run autos, and I have broken or burned up many of them. I prefer autos (makes it eaier to talk on my cell phone and drive /forums/images/graemlins/histerical.gif). I have been considering switching to a manual with the hydro clutch, I'm tired of replacing autos too.
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    ok so far we have 5 manual and 0 Auto. Anyone else? /forums/images/graemlins/thinking.gif
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Well I have been AVG about 1 trans per year. /forums/images/graemlins/blush.gif I like to hot rod a little on the road too /forums/images/graemlins/peace.gif
  12. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Lets make it 6 to 0 One more for the manual
  13. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    I havent had a SM465 4-speed since 1990 when I sold my 72 K5--it was a TH350 when I got it--for 3 years I had to wait every morning until the motor warmed up before it would go into any forward gears--once it went in you could drive it 500 miles without a problem--until you shut if off overnight,then the same thing--never did figure it out,so before I got fired from my job for being late all the time I bought the standard tranny,bellhousing,flywheel and clutch,transfer case out of a wrecked blazer--only trouble I had after that was the rebuilt 12 inch clutch I put in was a borg warner POS,the pressure plate died twice in 1 month--then the splines on the tranny shaft were worn,so it slowly ate the coupler between the tranny and transfer--pulled the case out and replaced that coupler twice--the last time I packed it full of J-B Weld!It made a very annoying rattle till I did that--sold it shortly thereafter.I like the standard for its granny low,and for off roading you cant beat the engine braking--but since 95% of my driving is on the street,I prefer the automatic--plowing with a standard sucks,your left leg is twice as big as the right after a big storm,and you eat clutches big time,I like the automatics for plowing better--the TH350 isnt that great of a tranny for heavy duty use,though I have one in my 74 K20 that had a 454 hooked to it for 5 years,now its a 400 small block--still working ok,but its getting slower shifting into reverse lately--sign of impending doom?. GM should have offered only the TH400 as the only automatic in 4x4's in my opinion. :crazy
    I'd say manual for wheeling or towing,automatic for normal street use.
  14. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    And just think of all the extra power to the ground you will get with that manual I forget exactly but doesn't the th350 sap 35hp and the th400 around 50hp?
    Anyways if you do do the swap just make sure you buy a high performance clutch (like the LUK clutches) and get yourself the hydro-clutch at the same time and you will be a very happy man.
    I hammer on mine all the time, shift without clutching, etc.. and it has never once complained or shown any signs of breaking down.
    Oh and the granny low gear sure helps you save your brakes. /forums/images/graemlins/deal.gif which in turn saves you money, which leads to more mods
    Come on now, isn't it obvious yet /forums/images/graemlins/pimp1.gif
  15. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    which in turn saves you money, which leads to more mods, which lead to more chicks hanging around your truck, which leads to getting laid
    NOW it makes sense! /forums/images/graemlins/waytogo.gif
  16. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    ha ha I stand corrected /forums/images/graemlins/grin.gif
  17. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    Manual is that only way to go. i have had two blazers with sm465's and never thouth once about swiching to auto. /forums/images/graemlins/peace.gif
  18. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    another one for manual, and everytime this kinda post comes up it is always in favor of the manual. /forums/images/graemlins/peace.gif
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd be wondering why the automadic transmissions keep failing. I do like the sm465 manual transmission, but in the mud, and everyday driving a automadic is nice.
  20. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    make it 1 for the auto's /forums/images/graemlins/blush.gif
    I perfer autos in mud so you can concentrate on driving, not shiftingg or down shifting /forums/images/graemlins/dunno.gif
    Although I like manuals too. make it a vote for a manual too /forums/images/graemlins/peace.gif
