Manual Swap, clutch problems.
Discussion in 'The Garage' started by petryshyn, Oct 19, 2005.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    I just finished up swaping a sm465 from a 82 1 ton into my 86 blazer. When I tried to hook up the z-bar it will not fit between the bellhousing and the bracket, it is about a 1" or 2" away from the bellhousing when on the bracket, am i doing something wrong, or is a 86 blazer meant for hydralic?
  2. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    could bee...
    I know my friends 86 K20 has a hydraulic clutch master and slave cylinder in it..I dont know the exact year they changed from manual to hydraulic,but it was right around that year ,somewhere in the mid-80's..No way to make the manual setup work??..maybe someone else here has done it,and will know more... :confused: :crazy: ...
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    85 and later was hydro... but i cannot imagine they changed the frame to match...
    i would think you can just move the z-bar bracket mount points without any issues
    oh, and just a simple thing: verify that you have the correct z-bar as well
  4. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    Yeah I am not to sure about the correct z-bar, its from a 82 1ton, I got the guys at the dealership to look up the part number and they said they were the same, can anyone confirm this?
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I cannot confirm that part.. but can you measure the length? I have one on my garage floor.. non paying ebayer :doah:
  6. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    Mine is 8.5" steel do steel, out of a 1982 1 ton 4x4, do you mind measuring yours?
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    just gotta let me get home from work first... @ 4:15 I should be home
  8. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    K, thanks.
  9. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    the bracket you are talking about, is it the one on the frame?? did you change it?? if not that bracket is for the shift rod for the auto
  10. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    no i put the bracket off the 1 ton frame onto my blazer one.
  11. RootBreaker
    Nov 29, 2001
    5,117
    173
    we are talking the z-bar.. hoepfully he put that in from the manual.... it has a ball at one end to go into the bellhousing... and slides over the piece that bolts to the frame.. or rivited..... anyhow I didnt get to check.. was busy... ya didnt call me or pm me back!!! ill try later....
  12. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Mine is the same....'80 K30
  13. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I know this post is a little old, but any help would be greatly appreciated. Anybody have a picture of the Z-bar bracker, how it bolts to the bell housing, or the frame. Anything would help at this point...
  14. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I have a 87 that I put the sm465 in and the donor was a 79 truck and it all fit just fine the holes where even in the frame for the zbar
  15. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
  16. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    That helped a lot, thanks! I just need to get the bushings etc...I got th eZ-bar so am gettign close!
  17. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    I now have everything installed except that bracket that goes on the frame...anybody have any idea where to get one? I can probably fab one up if someone was willing to give me dimensions...please?
  18. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It is GM Part number 6264942, available from GMPartsdirect.com or your local GM dealer. You could find in junkyards I'm sure too, but it's rivited on,so bring your cordless grinder....
  19. RootBreaker
    Nov 29, 2001
    5,117
    173
    yeah mine is still on my frame.... however I will take mine off once I do the crew cab drop.... :wink1:
  20. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Perfect, I ordered the part this morning. With any luck I should have it, and then my truck back on the road, within a short period of time. Thank you for all the help. Merry Christmas...
