Manual to auto transmision swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by taz8000, Mar 19, 2002.
  1. taz8000
    taz8000 Guest
    I own a 81 pick-up truck with a manual transmision and would like to change this over to a TH700R auto trannie, is this possible. I have a trannie and torque convertor out of a 85 6.2 Diesel Suburban.
    Can I use the same drive shaft (is the manual trannie as long as the auto)
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You will need driveshafts from a 81-91 truck, and you would have to change governors in the tranny unless your truck is a diesel.
  3. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    Also keep in mind the spline count out of your current tranny and the one you plan to install. you might need to change your t-case along with your tranny.
    Tom
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What manual do you have in your truck and what t-case do you have?I am guessing a 465/203 (???) combo...It is very possible...I am in the process of going the other way (auto->manual)...Here are some things to keep in mind...
    1. If you have the 700r4 and the TC, you MAY need a new t-case or and adapter to make your current t-case work with your auto tranny...I would try to find a 208 t-case w/ 700 adapter to simplify things
    2. You will need to get a bracket to hook up the TV cable to your throtle linkage at the carb (<a target="_blank" href=http://www.tvmadeez.com>Try TV MADE EASY</a>).
    3. You will need the auto shifter assembly
    4. A new cross-member
    5. New drive shafts (fornt and rear) probably just yank 'em from a similar year truck with an auto
    6. A new flexplate and possibly a new starter for your engine...
    I think that is it...If I thinik of anyhting else to consider, I will let you know...
    Chris
  5. taz8000
    taz8000 Guest
    I forgot to mention it is a 4x2 truck.
    BTW, what is a governor
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    81 would have a 32 spline SM 465 mated to a NP208. The 700R-4 is a 27 spline output so it won't bolt up to the T-case.
    The best way to accomplish the swap would be to find a tranny/T-case combo and swap the works...
    Personally I'd keep the SM 465 though, it's about 10 times stronger and more reliable than the 700R-4.
    Rene
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    If it's a 2wd truck...It easy...Just get a driveshaft from that year truck w/ and auto, get the shifter assembly and the TV cable bracket, flex plate and have at it...
    Chris
