manual to power doors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, Apr 27, 2004.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    Kind of along the same lines as xdelirious45x's post about the tailgate window; is it possible to convert a door's manual lock and window crank to power ones? Is it as simple as running the wires and installing a motor or is it just too ridiculous to deal with?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    It's sort of depends on the years. The newer(push in blade fuse style) fuse boxes have a spot for the wiring to clip right into. Which is different from the earlier design. I don't know what the year split was. The wiring comes as a complete unit. The only part of that that is a pain, is that it runs through the upper part of the dash. The dash pad has to come out and the wiring runs behind the guages, over the top of the heater and down into both kick panels to the doors. Holes will have to be drilled in the door pillar and in the doors. I have only been able to do this with the doors off. As far as the parts in the doors. You will have to pull the windows out and put the whole power window regulater in. The door lock selonoid just bolts in and has a single rod. No biggie. Not hard, but can be time consuming. what years are the donor and the truck your installing into??
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Since yours is an 87 you might be able to get the harness at the boneyard. As long as you get the harness the rest is easy...
  4. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    Haven't found a donor yet, but I di need to replace the entire passenger side door (preferrably sooner rather than later). Thanks for the info, now I know I don't have to be AS picky when I'm getting a replacement door.
  5. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    bablazer is correct simple but time consuming. I have removed and reinstalled several and I think all years are the same (excluding 73-75) but I am not 100% sure. I have a complete conversion on ebay (shameless plug /forums/images/graemlins/whistling.gif).
    ebay link
