Manual tranny fluid
Discussion in 'The Garage' started by Mreetz, Sep 12, 2002.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Pardon my memory, but.....what kind of gear oil goes into a manual transmission. Need to pick some up on the way home and cannot remember.....
    Thanks! /forums/images/icons/blush.gif
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    W/O overdrive use 80w gl5 gear lube
    With overdrive use dexron ATF /forums/images/icons/wink.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    SAE 80W GL-5 lube.
    (If it's a 4 speed manual w/ overdrive, then use Dexron ATF)
  4. Mreetz
    Jun 26, 2001
    1,282
    GREAT!
    Thanks guys!
