Manual Tranny fluid?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaveBlazin, Feb 9, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Looked in the search but could'nt find anything. Whats a good fluid to use in my SM465 and my NP208 any recommendations. Thanks,
    Spence
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    The 465 uses gear oil & the 208 uses tranny fluid. If you're looking for a good brand, who knows. I figured they're all the same.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Gear oil, 85/140
    I buy Coastal gear oil in a 25 pound bucket - it's the cheapest way. I'm on my second bucket /forums/images/graemlins/smile.gif
    I use it all the time - both axles in my Chevy, the 465, the 205, and the rear axle in my Dodge DD.
    -- Mike
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well for a Good Gear oil or Eng. oil for that matter I would say any of Amsoils products would work for you.
    Eric
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    85\140 /forums/images/graemlins/blush.gif, in a 465 i run 80\90 in my trucks 465, front 10 bolt and rear 12 bolt, why the heavy lube, does it work that much better?
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    85/140 is thicker, lubes better but has more drag.
    If you want more protection quieter operation and don't mind the 1% loss in fuel economy go with the thicker oil.
    If you are looking for the last HP you can squeeze out of you engine go with the thinner, even 75/90 synthetic.
  7. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Nice self-promotion there, Highlander. /forums/images/graemlins/rotfl.gif
  8. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Ok so pretty much all the thicker weight gear oil is good as for the transer case I should use normal dextron III or what.
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 241, 208 and the newer 205 (slip yoke) will use Dexron III or any ATF.
  10. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Thanks again yall!!!!
