Manual Tranny Gurus Needed!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jul 23, 2003.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    I just got my Borg-Warner T-19 back from getting rebuilt and installed in my tow rig. Nice and quite now, gee I thought it was supposed to be noisy, but now it won't hold 4th. It goes in, but let off the throttle and it pops out. Doesen't seem to engage as deeply as 1,2,&3rd. So look in the Haynes and they list this exact problem, say to retorque tranny to bellhousing bolt and make sure clean and aligned. Did all that. HELP, supposed to be using it tommorow evening.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Go ream the dude that built it...I'd be /forums/images/graemlins/angryfire.gif as hell...Or don't use 4th /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    That is a problem with the 3-4 synchro. The SM 465's do that with 3 rd gear quite often when they get really worn. On the synchro there are a few spring steel clips that the collar has to slide over when you change gears. These clips keep it in gear. Either this guy forgot or re-used the old ones.
    Go ream him out...
    Rene
  4. BowtieGuy3
    BowtieGuy3 Guest
    In my opinion, I'd say you might have to re-adjust your shift stops on your shifter. I mean everthing sems to be goingfine, but with rebuild, the tolerances change compard to your old gearbox, so it jus might be as simple as adjusting the shift lever to compensate for the new stuff.... /forums/images/graemlins/thumb.gif
