Manual Tranny Noise
Discussion in 'The Garage' started by WRENCH-HEAD, Mar 10, 2006.
  1. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    About a month ago I purchased a 95 two door tahoe with the nv3500 manual tranny in it. I have noticed a whining/rattling sound when the truck is neutral at a stop with the clutch out. When you press in the clutch the sound goes away? It also grinds going into reverse if you don't sit for a couple of seconds with the clutch pressed in. Any ideas? TIA
    -Alex
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    The first problem sound like your throw out bearing on your clutch, so figure on putting a clutch in it soon and don't wait to long or you can spin that bearing and gall your in put shaft sleeve.
    The second problem my not be a problem at all because reverse is non-syncronized and it takes a second or two for the gears to stop spinning inside. I have driven plenty of trucks that do that and also do it in the non-sync. first gear of the older tranys, you get used to it.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Agree with the clutch thing....sounds like it's almost time.
  4. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Thanks, that is what I thought just wanted to verify. I don't have much faith in the NV 3500.
    --Alex
  5. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    I called a guy I know that works at a tranny shop and he said that if it was the throwout bearing it would make noise when the clutch was depressed not released. Any input on this. The clutch and throwout bearing were on my "to do" list, but if this is true I might be adding more. Any thoughts?
    --Alex
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    It will make noise ,if bad, when under starin while being depressed for sure but you can also have a noise coming from the bearing dancing around the input collar for several reasons which is what you might be hearing.
    Those tranny's are also known for bearing wear as the miles rack up. The ATF that is used in them does not give the bearings what they need for lube film thickness. You might be hearing the bearing rattle too.
    Tom
  7. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I have had several t/o bearings make noise when setting and then stop/change sound when the pedal is pressed, just my .02.
  8. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    I'm gonna go ahead and change the clutch and the bearing and see what that does. Thanks for the info.
    --Alex
