Manual Tranny Noise
Discussion in '1992-Present Chevy & GMC models' started by WRENCH-HEAD, Mar 11, 2006.
  1. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    About a month ago I purchased a 95 two door tahoe with the nv3500 manual tranny in it. I have noticed a whining/rattling sound when the truck is neutral at a stop with the clutch out. When you press in the clutch the sound goes away? It also grinds going into reverse if you don't sit for a couple of seconds with the clutch pressed in. Any ideas? :confused:
    -Alex
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    sounds like input bearing and syncros are worn . but cant recall if the nv3500 are synced in revers.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    For the grinding, just shift into 2nd, THEN to reverse, without letting out the cluth in between. It shouldn't grind then. :)
  4. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Thanks, some said it was the throwout bearing, but I thought that was only when the clutch was pressed in. As far as the reverse thing, it isn't that bad just got to work around it.
    --Alex
  5. sweetk30
    Nov 1, 2004
    25,546
    542
    correct only when pressure is on it will that make much noise.
