Manual trans conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky87k5, Jun 26, 2001.
  1. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    How hard is it to convert Auto trans equipted trucks to manual trans setup. Are clutch & brake pedals available? Is hydralic clutch parts still available from GM? Looking at building a late model Sub 4x4 into 1 ton HD tow rig & selling my K5. Can't seem to find a 86-91 manual trans version. Did they make them?
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Ya, they made them, but not many. I would go with a hyduralic version though. The older style will wear your leg out quick in traffic. My left leg is still bigger than the right one LOL!!!
    <font color=purple>Have you hugged your K5 today?</font color=purple>
  3. Sparky87k5
    May 6, 2001
    726
    Have had both types of clutch setups & much prefer the hyd. setup too. Wouldn't mind a conversion if I could locate the parts needed. I believe I'll need both pedals and hyd. master cylinder. Slave cylinder is easiest to find. J**ps work great.
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    You might be able to pull a set up out of a early 90's 3/4 ton pickup. You'd have a 5 spd with a granny gear!
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Hi Sparky I converted my '87 a few years ago. Had same problem, could not
    find a manual trans. I found many parts at dealer but the swap was
    not cheap to do. I used Toyota FJ40 slave cyl. The other stuff was all
    GM. Best modification I have ever done.
    SteveB
