manual valve body th400
Discussion in 'The Garage' started by noho blazen, Oct 19, 2006.
  1. noho blazen
    noho blazen Registered Member
    Oct 7, 2006
    19
    mass
    i got a offer to get a th400 with manual valve body rebuild $500 i was just wondering on how would this would work in the mud and rocks and if i did get this tranny i would want a floor shifter and how would make the reverse lights work
  2. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    When you purchase a floor shifter it usually comes with an instruction manual. Which shows you how to wire up the reverse light. I'm running a B&M truck megashifter. IIRC you need to splice into a wire running to the reverse lights under the dash & wire it to a switch mounted on shifter which is activated when reverse is selected. With the maual valve body its P R N D 2 1 ideally you would want a reverse valve body so you selection would be P-R-N-1-2-D would make shifting easier when you would have to rock the truck from forward to reverse to free yourself. Hope this helps. - Jay
  3. noho blazen
    Oct 7, 2006
    19
    mass
    thanks that helps me alot
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    A manual valve body will shift very hard so make sure that is what you want.
