Manual vs.Hydro
Discussion in 'The Garage' started by johnathan, May 8, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Why is it hydraulic clutch setup prized over the manual setup?Is it for the ease of operation,more durable?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i dont think anyone has sucessfully bound up a hydraulic clutch linkage when flexed out yet...
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    OOHHH! I see now! That something to consider huh
  4. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    the only thing I dont like about hydraulic is that it can spring a leak, and then your stuck until you get it fixed. Found this the hard way on the way to work.
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Ah, just power shift the sucker :D
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    I had trouble with the clutch not disengaging when the truck was flexed out (manual clutch). I replaced the 25 year old body mounts with new poly ones. Pretty much fixed the problem 100%. I currently have no plans on switching to a hydro one.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    this has been hit on so much... do a search and you will find all the reasons why.....
    first....
    I bought a 1985 fullsize GMC Jimmy for $100 so I had EVERY part I needed... but the factory hydro setup is awww so sweet over mechanical.
    mechanical = adjusting
    hydro = no adjusting
    hydro doesnt have that huge return spring so your leg will appreciate it
    when I bought the truck back in 1989 I did a full body swap to what I am driving now in 1992.... didnt look over the truck as I was a youngin...
    was driving... tranny bolts to the tranny member were not there.. tranny shifted to the right when I turned left... pushed clutch in and went to the floor... clutch rod popped out... luckily I had my big craftsman screwdriver and got it back together.....
    they are just a few reasons...
    now I do see that my delema with the tranny shifting.. could have ripped out the mechanical clutch cable...then it would have been interesting....:haha:
