manually loading suspension?
Discussion in 'Center Of Gravity' started by sled_dog, Jun 5, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what would be the advantages of this? I understand mounting an ATV winch and preloading your suspension with it, but how does this help you? I just got finished reading over some UROC coverage over on Pirate and saw a few rigs running this, someone explain please?
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Several possible benefits. Main is to prevent the suspension from *unloading* when going up due to weight transfer to the rear. This raises the CoG which causes more weight transfer, and so on. Pulling it down lowers the CoG to start with and reduces the effect of weight transfer.
    It also provides side benefits like better visibility and more preload helps control instability and bouncing to some extent.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Pulling the front down will also move your center of gravity forward . Which it what helps the steep climbs.
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Don't forget about the most important part... it helps you fight those tickets you get for being over the legal height limit /forums/images/graemlins/thumb.gif
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I wish. /forums/images/graemlins/grin.gif
    I'm way past that point. /forums/images/graemlins/tongue.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    heh, not the only one
  7. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Same here... we're only allowed 3" of lift and 33" tires on K5's in Mass. I've got 6" of lift and 40" tires, go figure /forums/images/graemlins/rolleyes.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    My bumpers are actually barely legal here. I'm only running 5" of lift. ITs the tires sticking way way out that does me in. /forums/images/graemlins/dunno.gif
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    im really thinking of running air cylinders at each of the front corners.
    i could either suck up the axle with about 1200 lbs of force, or force either side down with 700 lbs... or push down with both...
    just trying to figure out the solenoid valving /forums/images/graemlins/thumb.gif
  10. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I think you first need to figure out how to keep your tail lights attached to the truck and how to keep your toolbox from falling out. /forums/images/graemlins/rotfl.gif
  11. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i've duct taped that tail light in after every run.... /forums/images/graemlins/peace.gif
  12. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    Most people that use the winch to suck the front end down do it because a coil sprung suspension pushes the body away until something stops it. I use my winch to suck the front end down on climbs all of the time and it makes a huge difference in the way the buggy feels on climbs.
    This weekend we were running carnage canyon in Buena Vista and I had the winch hooked up to the axle for the last climb. When I released the winch for someone to attach it to the winch anchor because I couldn't make it the front end pushed away so much that I was a little nervous about going over backwards.
    It really helps to keep the front tires loaded with some weight. As the body pushes away the front tires go to basically having no presure on them. Therfore no traction.
    I have watched Stephen do the same climb in his Blazer with leaf springs, Coilovers with no front limiting strap, and then with a center limiting strap that holds the front axle at ride height.
    The leaf springs did not appear to have any bad push away
    The coils with no front limiting strap made the front go to full droop then lift the front tires. It looked a little scary.
    Then by adding the front limit strap the blazer climbed better than it had with the leaf springs. This was because the weight of the front axle helps to keep the body down which in turn makes the body put more weight on the front tires. Which equals better traction.
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They also use them as a flex limiter. Sometimes less flex can keep the front end out of big holes. But I believe the main advantage is climbing.
