manuals and autos
Discussion in 'The Garage' started by 84gmcjimmy, Jun 28, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, I will be getting an th400 for the blazer in august, and put it in sometime before school. So I have a question, it already has an auto in there, but what difference in unbolting and bolting up is there from a manual? I unbolted and bolted up a sm465/208 5 seperate times 2 winters ago so I know how to do that, so is there any different proceedure? What about the colum shifter link and whatnot. Sorry I am not wise about autos so go easy on me!
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Are you wanting to know what to do to unhook it from the engine?
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    The auto IMO is easier than the stick. For removal (reverse for installation) unbolt the torque converter, disconnect tranny fluid lines, pull small pin and unhook shift linkage, disconnect the kickdown cable, unbolt from motor and tranny crossmember and viola. It's out. The hardest part of installation and the easiest way to screw up a tranny is resetting the kickdown cable as it needs to be adjusted correctly.
    EDIT: I forgot there is a vacuum hose running to the modulator that will need disconnected.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is no kickdown cable on a TH 400. It is an electrical connection on the driver's side that provides the kickdown.
    I wouldn't say one or the other is easier. I've got a TH 400 in my tow rig and a 465/205 in the trail rig. I dreadl pulling transmissions because of the weight, not because one is auto or manual.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    come on Tim hooking up an auto is so much easier. All you do is guide it up in there and bolt it to the motor, then rotate till you can bolt up the torque converter and voila. With the stick you have to guide that damn input shaft through the splines of the clutch then into the pilot bearing on the motor. If you have a trick that makes this easy PLEASE share cause it takes me a couple hours everytime I install a trans.
    84gmcjimmy - you haven't mentioned clutch stuff. You need a clutch pedal assembly. Preferably hydraulic. Without that a 4 speed is a waste of time seeing as its unusable.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Sled_dog, I don't understand your last sentence, the th-400 is a 3 speed auto, so it doesn't need a clutch.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was talking about swapping to a manual. Its not as simple as bolting it in /forums/images/graemlins/wink.gif
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I know I know, I was just going through it quickly, trust me its alot harder than I said. Like I said I had to do it around 5 times in winter weather in about a week. We had to do it so many times because the shaft the clutch assembly goes onto had a torque in it. So we had to take it to a tranny shop to get fixed.
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    A clutch takes a bit more dedication to install.
    But not much more than a slush box.
    Remove about 200 Mack trannys, we call em Maytags because they are about the size of a friggin refrigerator.
    465's are small. LOL
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm well aware 465s are small but I prefer to remove the motor rather than the trans, its easier. The motor in my burb needs a new flywheel, I was gonna drop the trans but forget that be easier to pull the motor, think I will replace the motor with a roller one anyway.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I put it in gear and spin the output shaft. Hasn't failed me yet, last time I installed my trans/case in about 3 hours from start to finish.
